Is there a way to set up the guest network to use PiHole as its DNS when it is set to block Access to Intranet?
I tried the following:
LAN > DHCP Server > DNS Server 1 - Set PiHole IP
Result: Works for wireless AP and ports directly connected to Internet, but doesn't work on the Guest Wifi. I'm thinking because its set to block access to Intranet.
LAN > DNSFilter > Enable DNS-based Filtering
Global Filter mode - Custom 1
Custom (user-defined) DNS 1 - Set PiHole IP
Result: No internet access on entire network.
WAN > Internet Connection > DNS Server1 - Set PiHole IP
Result: Works on all AP including guest netowork. But on the pihole logs, I only see the router gateway as sending all DNS requests.
I don't mind using the WAN option. But I wanted to be able to see the devices properly on piHole. Any way to set it up that way? I also need Guest network to block access to Intranet.
