asus rt-ac86u WAN Fail to connect with some issues
wcukewa
i purchased a new asus rt-ac86u. connected to existing adsl modem (Linksys WAG320N) and i cam getting constant WAN connection fails, about every 5 to 15mins.
asus(192.168.0.2) is configured to stand router mode. WAN is set to static connected to WAG320N(192.168.0.1)
WAG320N is in adsl2+ with router and dhcp disabled, DMZ on router IP.
initially i had WAG320N in bridge mode, but getting constant ppp dropout, so i changed to this setup to double check that adsl the issue or not.
Currently having the WAG320N up and running without dropout for 2 full days, while connection between asus rt-ac86u and WAG320N is drop every 5-15mins.
Router
Model
RT-AC86U
Firmware Version 384.7_beta1
Firmware Build Sat Sep 15 03:43:32 UTC 2018 merlin@0de7c61
Bootloader (CFE) 1.0.0.6
Driver version wl0: May 24 2018 16:52:46 version 10.10.122.20 (r683106)
Temperatures 2.4 GHz: 53°C - 5 GHz: 58°C - CPU: 74°C
CPU
CPU Model
Cortex B53 ARMv8 (Cores: 2)
CPU Frequency 1800 MHz
CPU Load Average (1, 5, 15 mins) 3.12, 3.09, 3.03
Memory
Total
430.11 MB
Free 224.82 MB
Buffers 0.00 MB
Cache 21.18 MB
Swap 0.00 / 0.00 MB
Internal Storage
NVRAM usage
61773 / 131072 bytes
JFFS 1.38 / 48.00 MB
Network
HW acceleration
Runner: Disabled (QoS) - Flow Cache: Disabled (QoS)
Connections 348 / 300000 - 94 active
Basic Config
WAN Connection Type
Enable WAN
Yes
UPnP FAQ Yes
Enable secure UPnP mode Yes
WAN IP Setting
IP Address
192.168.0.2
Subnet Mask 255.255.255.0
Default Gateway 192.168.0.1
WAN DNS Setting
DNS Server1
8.8.8.8
DNS Server2 180.76.76.76
edit: i tried with firmware 384.6 and 384.7, same thing happens. is it the asus having hardware issues?
