Hello Everyone,
I am having a weird issue, I hope you can help in solving it. My setup is the following: a DSL-AC68VG operates in modem only mode, behind it there is an RT-AC86U (router #1) which is the AiMesh router and there is a second RT-AC86U (router #2) to extend the coverage as an AiMesh node. I have my 2.4Ghz and 5Ghz networks separated with different SSIDs.
When I checked the AiMesh router admin page, I was seeing that the link between the two APs turned to weak in the AiMesh control panel. In the past it was operating without any issues and showed strong signal for the AiMesh node. After further digging into the settings I realized that the uplink is 2.4GHz only. I have tried to disable the 2.4GHz radio in the AiMesh settings for router #2 to trigger the device to use 5Ghz only but the only thing I have achieved with this to be completely unable to connect to any of the wireless networks. The AiMesh network dropped as well so I had no other choice than to reset the both routers #1 and #2 hoping that it will solve the issue. This is where the fun began: regardless of doing a soft (using the reset button on the back) or a hard reset (using the WPS button method) and both of the radios active, router #1 was showing a seemingly operating 5GHz network, but it did not allow to connect any device to it (the 2.4GHz network worked flawlessly in parallel). I was also trying to connect router #2 with AiMesh and after 2-3% progress the connection process failed with an error message.
As an alternative solution I thought to replace router #1 with #2 to see what happens. Surprisingly, with router #2 being set up as the AiMesh router both networks were visible and OK to connect to. AiMesh setup with router #1 as a node was also completed. Still the uplink is 2.4GHz only and weak, and if I would like to get a more distant device connect to the 5GHz network (presumably using the AiMesh node as the connection point) it fails. All of the devices that were set up for the 5GHz network are connecting straightaway to the AiMesh router (router #2) leaving the AiMesh node out of the picture (router #1). I am a bit clueless as I am not using the DFS channels and the channel selection is set to Auto to eliminate any potential connection issue. Is there any other setting which would prevent me from achieving what I want?
Both devices are approximately the same old and are running the same firmware, which is the latest Merlin build (386.13_2). I am aware that these devices are EOL but I would need to make this setup working for the time being potentially without exchanging to another device. I hope there will be some way forward since it was working without issues for weeks before this phenomenon started to happen. I doubt that only the 5GHz functionality died in router #1 (or at least I hope it did not), but of course I am not ruling this one out as the potential root cause. Any idea or support would be highly appreciated, thank you very much in advance!
