Louis James
Good Morning:
Is it possible that Build 3.84.13_10 is blocking iCloud on both Wired and Wireless Connections. My wife's iPhone can access her photos while on Cellular Data. However, put the phone on Wifi and it will not access anything in Photos (or iCloud for that matter).
Even the computer can't access any photos on icloud.com.
I find it hard to believe that somehow the Router is Blocking the service but I have no other option to consider unless I'm messing something. By the way, reset the phone network settings (and all settings) and no luck. And it is happening to two different Windows 10 systems as well. What is common is the Router.
I would be grateful for any thoughts. Thank you.
Regards:
Louis
Regards:
Louis
