ASUS RT-AC87U Firmware version 3.0.0.4.382.51939 (2019/11/20)
triple
Version 3.0.0.4.382.51939
2019/11/20
42.53 MBytes
- Fixed Let's encrypt register issues.
- Fixed Network map client list issues.
- Fixed OpenVPN related bugs.
- Fixed schedule reboot bugs.
- Improved system stability.
- Fixed dual wan failover bugs while the primary wan type is L2TP.
Please unzip the firmware file first then check the MD5 code.
MD5: 8c276977dfef51cd7b671fa3e4ff1230
https://www.asus.com/Networking/RTAC87U/HelpDesk_Download/ (OS: Other)
https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AC87U/FW_RT_AC87U_300438251939.zip
Too bad it is still on the old 382 branches. :(
Hi, everybody.
Anyone install new firmware RT-AC87R? Version 3.0.0.4.382.52230 2020/05/06
Hi, everybody.
RT-AC87R or RT-AC87U?, I have instaled in RT-AC87U (Operation Mode:Wireless router Firmware Version:3.0.0.4.382_52230 ) at 1 day and 4 hours. So far so good.
WHY?
WHY?
Thanks. RT-AC87U is the same RT-AC87R.
Because this:
Support router certificate export. After import the certificate to the computer you will not see the warning message when login with https.Please refer to https://www.asus.com/us/support/FAQ/1034294/
Did you have to install the certificate? Everything fine?
I read the FAQ and a lot of instruction for little, I believe. Will it only be for access to the router, or will it interfere with browsing other pages?
