I have been having a problem with wireless AC (5GHz) band disconnecting about every 10-30 seconds. I discovered that I could change the wireless mode from Auto to N Only and the channel bandwidth set to 20 MHz and the problem would go away. I have been running test to see if I could get the Auto wireless mode to work again. I set the channel bandwidth to 80 MHz and I found that any control channel above 48 would cause the 5GHz to go down in about a minute. Once I set the control channel to 48, I got a stable connection. I have been streaming HD video from my surveillance cameras at 4250 kb/s for about 40 minutes and have had no drops. I have not tested any of the other control channels. Once I found one that worked, I stopped. Intel's wireless software is reporting that I am getting 866.7 Mbps with this setting.
I hope this can help anyone else with this problem.
