I'm using snmp to report devices status using several devices and SO (Synology, AsusWRT, LEDE/OpenWRT). Regarding the interfaces speed (ifSpeed parameter) ASUSWRT is the only that is reporting all the interfaces as 10 Mbps (ifSpeed=>10000000) when they should report 1Gbps. I'm using Observium as Monitoring platform.
This speed are configured only for loopback interfaces and the following devices should correspond with the switch speed. On all my devices, this is the only with AsusWRT and is the only that are wrongly reporting interfaces speed.
I'm using standard admin snmp configuration page to set it.
How can i correct or when it will be possible to be corrected in a future firmware upgrade?
