Asus RT-AC87U
LXEvans
I'm new here
how risky is it to brick my Wlan Router when i replace the firmware with the Merlin one? how can i go back to the original Firmware, do i lose Warranty when i do this?
thanks for your help
kind regards
Not very risky at all, its like flashing asus own firmware. Just take the normal precautions eg dont remove the power during.
Warranty, not sure I doubt it would be a problem.
Merlin is in close contact with Asus and his version is approved by Asus! So there is no risk over the original Asus version! :cool:
Of course you need to follow the recommendation about a NVRAM/factory default reset plus a power down AFTER the update/change of firmware as described here.
