I have an ASUS RT-AC88U running Asuswrt-Merlin firmware (version 386.2_4 at time of failure) it had been running without issue ~2 years (well there have been constant dropouts the past few months but connection is always res-established) but on Friday morning my internet connection dropped out - I connected up my ISP router and connected successfully so I performed the following steps:
1. Restored to factory settings, loaded known to be good config file - internet connection established then dropped after about 1 second
2. Restored to factory settings, manually configured connection - internet connection established then dropped after about 1 second
3. Loaded Asuswrt-Merlin version 386.1_0, restored to factory settings, manually configured connection - internet connection established then dropped after about 1 second
4. Loaded ASUS FW 3.0.0.4.386.41700, manually configured connection - internet connection established then dropped after about 1 second
5. Loaded Asuswrt-Merlin version 384.19_0 (as I had a known to be good config backup), restored config - internet connection established then dropped after about 1 second
6. Installed Asuswrt-Merlin version 386.2_4, restored to factory settings, manually configured connection and configured DUAL WAN with Ethernet LAN 2 acting as primary internet connection - no connection established.
If I leave the device sitting connected to the ONT the connection is established, an IP address is assigned from my ISP then the connection immediately drops, it goes through a connection and disconnection loop.
I stupidly did not obtain logs from the device before I reset but have since saved logs which show the connects/disconnects.
My ISP (Sky Ireland) have stated there has been no change on their end...
Apologies about the long post but can anyone help please?
Logs: https://1drv.ms/t/s!AsMiGK22s5rIoxDOmFPGtgERmHQB?e=nQFHPg
