ASUS RT-AC88U slow Wan Speeds
Cavey
Hello,
I like to check if anyone has has this issue and managed to solve it
I am currently on 350mbps, if i connect direct to the ONT modem, i get the full speed when using speedtest.net, however if i should connect to the Asus RT-AC88U with the firmware 380.58 i somehow only get 4mbps/ 1mbps (download / upload) speed when using speedtest.net. QOS and other traffic monitoring stuff is off. Using Wifi or wired is the same. Tried to factory reset etc.. doesnt help or work.
I tried the original firmware and its the same. Talking to the ISP, they say all is normal and no special settings has been or needs to be configured. Just curious if anyone has faced this issue and how it can be solved.
Thank you!
