Release ASUS RT-AX55 Firmware version 3.0.0.4.386_52294
Futuristic
Just a heads up, there‘s a new firmware posted on 11/8/23 - Loaded it up on my AX55 running in AP mode and all seems well so far.
Bug Fixes and Enhancements:
- Fixed IPv6 issue on Hinet MOD.
- Resolved OpenVPN server TAP mode issue.
- Fixed ipv6 network service filter not work.
- Fixed the registration failure after reboot when using account based DDNS
Security Fixes:
- Fixed several curl vulnerabilities.
- Fixed FFmpeg vulnerabilities.
- Fixed command Injection Issue after authentication
- Corrected an OpenVPN vulnerability categorized as CWE-134.
- Fixed Stored Cross Site Scripting.
After the update RT-AX55, the dual network stopped working. Resetting the router did not help.
The dual network is configured for failback. After the reset, the dual-band configuration works for a while. After that, dhcp requests to the provider from Lan port 1 stopped being sent.
UPD 06.16.2024
Downgraded the firmware version to 3.0.0.4.386_51598. Dual WAN works without any problems.
UPD 06.16.2024
Firmware 5203 is out. Might want to try that.
I got the wrong topic, that's what I meant to write about 386_52303. The firmware version 386_52303 was the one with the dual wan problem.
Also in version 3.0.0.4.386_52294 my bash scripts on cron stopped working. With curl requests. As long as you are connected via SSH, then cron works. As soon as you disconnect via SSH cron stops working. I don't understand what the reason is. But Dual wan works on version 3.0.0.0.4.386_52294.
After switching back to 3.0.0.0.4.386_51598 both dual wan and bash scripts via cron work.
UPD.
I found what the problem is with Dual wan :). If dual wan mode is enabled and "Guest Access" is enabled, the second wan port stops working.
