ASUS RT-AX55 High Memory usage
brunoschcabnc
SInce a few days, I noticed that my ASUS RT-AX55 has a High Memory usage, a reboot took it to a more normal, average usage around 85% but after only 4/5 days it comes back to high usage between 97 to 99% (!). Was never the case before (I monitor quite regurlarly in the app). There do not seem to have any negative effect for now on my WiFI connection etc but I think it is way outside of the ordinary to be on that edge! Could it be since last firmware update from September (I have 3.0.0.4.386_52041 version)? Can we expect a fix?
Thanks.
This is the cheapest Asus AX-class router with only 256MB RAM. I guess, there is nothing to fix. The firmware uses whatever is available and it's not much. If the router works properly - don't worry about it.
