ralong
I have RT-AX56U and the router keeps disconnecting my WIZ light bulbs, my ESP32, my tasmota devices. They are seen in the device list in the router. But I cant control them, and home assistant cant see them also.
And i don't mean they disconnect once in a while, but my kitchen bulb sometimes works for 5 minutes, and then i need to power off/on it. or reset the router, or of/on the wifi.
I tried turning the 5Ghz off, setting different channels, giving static IP, turning off WIFI 6/5/4 and nothing.
My firmware is Merlin: Current Version : 388.2_2
I tested a TP link router with wifi6 and everything was working fine (I tested it for 2 weeks). The wifi strength reported by the devices is even stronger with the ASUS router but its useless.
What can I do? Or does the ASUS routers just suck with 2,4Ghz network?
