Release Asus RT-AX58U Firmware 386.43588 (7-28-21)
  • Thread starter Deleted member 22229
  • Start date
D
Guest
Version 3.0.0.4.386.43588
2021/07/28 51.34 MBytes
ASUS RT-AX58U Firmware version 3.0.0.4.386.43588
1. Fix AiMesh issues.
2. Improve system stability.
3. Fix WAN DNS setting cannot setup LAN side pihole server.
4. Modify few IPTV settings.
5. Add IPv6Plus support.
6. Add Google assistant support. (app version later than 1.0.0.6.38)
>> RT-AX58U - DRIVER & TOOLS <<
Anyone (besides me *smile*) use the RT-AX3000 or RT-AX58U in media bridge mode? I tried 43406 and it didn't work right, seemed to disconnect fairly often. Hoping that this new version does work right. I don't want to waste time if it's known not to work, though. Had to revert to 41700 firmware after 43406 didn't work for me. 41700 seems fine, I can stay with it, but would like to go to newer firmware if I can.
Just wanted to indicate that I have upgraded successfully from this default ASUSWRT firmware (386_43588) to the Merlin firmware (386.3_2). No issues found on the RT-AX58U and everything works as expected thus far.
I use my RT-AX58 as a AiMesh Node, but it serves mostly as a wireless media bridge for my work laptop and my desktop. Like you described, I have had some issues with the router either disconnecting from my AT-AC86U or after about 2 weeks I start to loose bandwidth to the point where any client connected gets dial up like speed.
Then I upgraded to 386.43588 and so far it's been 3 weeks and I haven't had a disconnect or degraded bandwidth. Crossing my fingers in hopes that this is the fix we have all been waiting for.
