Release ASUS RT-AX58U Firmware version 3.0.0.4.388_23924
Calkulin
Bug fixes and function modifications:
-Fixed v6plus-Related Issues and Added OCN Support.
-Resolved OpenVPN Server TAP Mode Issue.
-Fixed the problem that the Aicloud app cannot add router on Android 9.
Security updates
-Corrected an OpenVPN vulnerability categorized as CWE-134.
-Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
-Fixed CVE-2023-32643,CVE-2021-27218, CVE-2023-38031, CVE-2023-38032, CVE-2023-38033,CVE-2023-39236,CVE-2023-39237,CVE-2023-39238,CVE-2023-39239,CVE-2023-39240
Please unzip the firmware file, and then verify the checksum.
SHA256: d67abc6f2e5f83eb2d53a0dce60c1fcabbc1e576bed93e9153646d4d445d4776
Two observations with the update.
1) I am getting a new hourly entry in the log file:
ddns: IP address, server and hostname have not changed since the last update.
I don't know if the update changed the log level or if this is new.
2) The Let Encrypt Server Certificate status is stuck at "Authorizing". I still have a valid cert, so maybe this will clear up at the next update.
Edit: v1 hardware
In case anyone else has cert status issue, I fixed it by changing the radio button to "Auto", apply, then back to "Free Certificate from Let's Encrypt", and apply again.
It is probably good to mention what router version you guys run this firmware on.
The file contains firmware images for both V1 and V2 - different hardware devices.
Version V2 must be written on the label. Also the GUI may give some clues - V1 is 3-core CPU, V2 is 4-core.
