Release ASUS RT-AX58U/RT-AX3000 Firmware version 3.0.0.4.386.48908 (2022/05/24)
visortgw
Version 3.0.0.4.386.48908
2022/05/24 107.59 MBytes
ASUS RT-AX58U Firmware version 3.0.0.4.386.48908
1.Fix IPv6+ related issues
2.Improve system stability
3.GUI bugs fixed.
Please unzip the firmware file first then check the MD5 code.
MD5: 84eda699d7ebe5ae552499768b71823d
(NOTE: Same firmware is available for both RT-AX58U and RT-AX3000.)
FWIW, I just updated, don't notice any problems. I am not using mesh at all though- just as a single router + PiHole.
Interesting that the AX3000 seems to be the first to get 489xx...
Can you check if there is a VPN Fusion option in the GUI, because in the previous version they replaced it with a simple VPN client ...
not sure what I'm looking for.. But these are the 3 VPN screens that I can see. I didn't see anything that said VPN fusion.
Thank you for the quick reply. It is really strange that with newer firmware they would remove the functions for which I bought this router ...
VPN Fusion is only available for ROG models. It was never available for the RT-AX58U.
VPN Multiclient is a new feature that is currently under development on the RC3 branch. I'm not sure why it would appear on your 47xxx build, it might have been a mistake, or that build was a beta test build and not an official release.
Sorry my mistake. I meant the multiple VPN client. The principle of operation of these functions is rather similar? From the build I had after buying the router through the next two, 45898 and 47029, this feature was present and I doubt it was a beta version because I downloaded the official build from the asus website. I will add that I have the RT-ax58U V2 version.
Is there a chance for Merlin software released for RT-AX58U V2 version?
I can't speculate about future model support.
