Release ASUS RT-AX59U Firmware version 3.0.0.4.388_33407
RT-AX59U.Japan
Version 3.0.0.4.388_33407
37.95 MB
2024/12/27
1. Improved the stability of AiMesh backhaul connections, resulting in a more robust and reliable mesh network performance.
2. Strengthened input validation and data processing workflows, further protecting your information security.
Please unzip the firmware file, and then verify the checksum.
SHA256: 189F69785031E9C79EEE6B8ACB659D61A540EDA9254A440EB3267E639A7A6025
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX59U/FW_RT_AX59U_300438833407.zip?model=RT-AX59U
Progress report as of now
Even after updating to this firmware, there have been many instances where the iPhone's Wi-Fi connection was interrupted or unstable during calls on the messenger app, but recently I found a few improvements.
- Stop building Mesh AI Wi-Fi
- Turn on the Smart Connect feature
- If building Mesh AI Wi-Fi, keep the distance between routers more than 5m. Also, set the roaming distance appropriately. For example, change the default value from -70 to -68.
- Do not use WPA3 when setting up Mesh AI Wi-Fi. Basically, set it up with WPA2.
