Volt
Version 3.0.0.4.388_33903
38.87 MB
2025/03/13
Bug fixes:
1.Fixed the UI issue in Chrome.
2.Enhanced input parameter handling techniques to improve data processing stability and system security.
3.Enhance system access control mechanisms.
SHA-256 :02583B0D0012EF1CB8D65EB39C96CEE0F9A1B2D660321F5FB0D6C6636BAEC7D8
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX59U/FW_RT_AX59U_300438833903.zip?model=RT-AX59U
Page with firmwares: https://www.asus.com/networking-iot...rs/rt-ax59u/helpdesk_bios?model2Name=RT-AX59U
Note (from me): Despite the fact that the list of fixes is small, a relatively large increase in the build number for MediaTek models suggests that the changes were most likely more significant. Indeed, on previous firmware versions I had periodic problems with the GeForce Now cloud gaming service, when there were latency spikes and the stream quality dropped for a couple of seconds, but in this version everything works much better (spikes are minimal, no stream quality loss).
38.87 MB
2025/03/13
Bug fixes:
