I have an Asus RT-AX86U running Merlin. I just got a new laptop and I can't connect it to my network share. It's working fine on the old laptop.
Enable sharing is on, device name is set, I have a workgroup name set that I also set on the laptop, protocol is SMBv2, simple sharing yes, force as master brower no, set as WINS server yes.
I then have a user set up with r/w access to some folders on the drive.
The device name appears in windows network section, but if I click it, it just says windows cannot access \\RT-AC68U-CR (yes, that's the name because I didn't want to change it from my old router). On the other laptop, if I click that, it shows all the folders on the drive.
Same error if I go to run and put in \\192.168.50.1
What am I missing here?
