MrAsusIsBack
Hello,
i have updated my RT-AX86U with the new firmware 3.0.0.4.386.45375.
Complete AiMesh menue now is unusable if in AP-Mode. Most fields on the right are blank or no reaction on pressing an button. Only the switch for Ethernet Backhaul can be activated.
Yes i use Asus routers long time ago and i do all typical things to do. Softreset, Hardreset incl. erase NVram, thousends of restarts etc., nothing help, also changing browser type doesn't help.
I updated via menue and also via file upload.
Normally in AiMesh menue on the right side they show that the router is in AP-Mode and has WAN connection. But with new firmware the fields are empty and connection is red. But Wifi works and you can go to the internet via the WAN connection.
I use the RT-AX86U as Mesh Master in AP-Mode. My two nodes RT-AX58U are connected via ethernet backhaul. So this is the first update from my RT-AX86U which complete fails. That really sucks.
If i go back to firmware version before, the RT-AX86U runs immediately without any reset etc. It takes the settings from the newer firmware and i only have to add the nodes again. That normally can't be really true?
Is there anyone which use the RT-AX86U in AP-Mode as Mesh Master which can confirm or please help me???
After some more tests, it's definitly a bug in AiMesh in AP-Mode. In AiMesh menue the router show the he has connection on second 5GHz Band (really funny to have now a triband router)
Conclusion: Be aware of this update if use in AP-Mode with AiMesh:-(
Do here nobody use this router in AP-Mode??
Thx.
By the way, I notice that in the thread of Asus AX routers it is teeming with problems while in the thread of Netgear AX routers there are often only questions about the settings. I also had the RT-AX55 and RT-AX68U. There were also those who always caused problems. ASUS-> Many functions but better not use anything .
Thx.
