Dec 9 10:55:13 rc_service: ntp 1645:notify_rc restart_diskmon
Dec 9 10:55:13 disk_monitor: Finish
Dec 9 10:55:13 disk monitor: be idle
Dec 9 10:55:14 kernel: random: nonblocking pool is initialized
Dec 9 10:55:14 httpd: Succeed to init SSL certificate...80
Dec 9 10:55:16 cfg_server: event: wl_chanspec_changed_action
Dec 9 10:55:16 cfg_server: skip event due no re
Dec 9 10:55:17 kernel: SHN Release Version: 2.0.1 4b635f32
Dec 9 10:55:17 kernel: UDB Core Version: 0.2.18
Dec 9 10:55:17 kernel: sizeof forward pkt param = 280
Dec 9 10:55:17 BWDPI: fun bitmap = 47f
Dec 9 10:55:17 cfg_server: event: wl_chanspec_changed_action
Dec 9 10:55:17 cfg_server: current chansp(unit0) is 1808
Dec 9 10:55:17 cfg_server: current chansp(unit1) is e832
Dec 9 10:55:17 cfg_server: dump exclchans:
Dec 9 10:55:17 cfg_server: old wl0_acs_excl_chans:0x100c,0x190a,0x100d,0x190b,0x100e,0x190c
Dec 9 10:55:17 cfg_server: new wl0_acs_excl_chans:0x100c,0x190a,0x100d,0x190b,0x100e,0x190c
Dec 9 10:55:17 cfg_server: old wl1_acs_excl_chans:0xd034,0xd038,0xd03c,0xd040,0xd936,0xd93e,0xd836,0xd83e,0xe03a,0xe13a,0xe23a,0xe33a,0xec32,0xed32,0xee32,0xef32,0xd064,0xd068,0xd06c,0xd070,0xd074,0xd078,0xd07c,0xd080,0xd084,0xd088,0xd08c,0xd966,0xd96e,0xd976,0xd97e,0xd986,0xd866,0xd86e,0xd876,0xd87e,0xd886,0xe06a,0xe07a,0xe16a,0xe17a,0xe26a,0xe27a,0xe36a,0xe37a,0xe872,0xe972,0xea72,0xeb72,0xec72,0xed72,0xee72,0xef72
Dec 9 10:55:17 cfg_server: new wl1_acs_excl_chans:0xd034,0xd038,0xd03c,0xd040,0xd936,0xd93e,0xd836,0xd83e,0xe03a,0xe13a,0xe23a,0xe33a,0xec32,0xed32,0xee32,0xef32,0xd024,0xd028,0xd02c,0xd030,0xd926,0xd92e,0xd826,0xd82e,0xe02a,0xe12a,0xe22a,0xe32a,0xe832,0xe932,0xea32,0xeb32
Dec 9 10:55:17 cfg_server: wl_chanspec_changed_action: Need to restart wireless due current 5G chanspec is un-available
Dec 9 10:55:17 rc_service: cfg_server 1448:notify_rc restart_wireless
Dec 9 10:55:19 kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 0
Dec 9 10:55:19 kernel: ^[[0;33;41m[ERROR vlan] vlanIoctl ,652: Failed to delete VLAN device eth6.501^[[0m
Dec 9 10:55:19 kernel: ^[[0;33;41m[ERROR vlan] vlanIoctl ,652: Failed to delete VLAN device eth7.501^[[0m
Dec 9 10:55:19 pppd[1400]: Modem hangup
Dec 9 10:55:19 zcip: iface br1 is down
Dec 9 10:55:19 avahi-daemon[1268]: IP_DROP_MEMBERSHIP failed: No such device
Dec 9 10:55:19 pppd[1400]: Connection terminated.
Dec 9 10:55:19 pppd[1400]: Failed to disconnect PPPoE socket: 114 Operation already in progress
Dec 9 10:55:19 pppd[1400]: send (sendPacket): No such device or address
Dec 9 10:55:19 kernel: wfd_registerdevice Successfully registered dev wl0.1 ifidx 1 wfd_idx 0
Dec 9 10:55:19 kernel: Register interface [wl0.1] MAC: 04:d4:c4:4f:6c:61
Dec 9 10:55:19 kernel: IGMP Query send failed
Dec 9 10:55:19 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
Dec 9 10:55:19 kernel: netdev path : eth6.0 -> eth6
Dec 9 10:55:19 kernel: BCMVLAN : eth6 mode was set to RG
Dec 9 10:55:19 kernel: netdev path : eth6.501 -> eth6
Dec 9 10:55:19 kernel: netdev path : eth7.0 -> eth7
Dec 9 10:55:19 kernel: BCMVLAN : eth7 mode was set to RG
Dec 9 10:55:19 kernel: netdev path : eth7.501 -> eth7
Dec 9 10:55:20 kernel: HTB: quantum of class 20010 is big. Consider r2q change.
Dec 9 10:55:20 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
Dec 9 10:55:20 kernel: HTB: quantum of class 20040 is big. Consider r2q change.
Dec 9 10:55:20 WAN Connection: Fail to connect with some issues.
Dec 9 10:55:21 acsd: eth6: Selecting 2g band ACS policy
Dec 9 10:55:21 wlceventd: wlceventd Start...
Dec 9 10:55:21 acsd: acsd_main_loop(1107): sync_id: 35210, status:1, misc.error/abort
Dec 9 10:55:21 acsd: eth6: selected channel spec: 0x1808 (6l)
Dec 9 10:55:21 acsd: eth6: Adjusted channel spec: 0x1808 (6l)
Dec 9 10:55:21 acsd: acs_set_chspec: 0x1808 (6l) for reason APCS_INIT
Dec 9 10:55:21 acsd: eth7: Selecting 5g band ACS policy
Dec 9 10:55:26 crond[1250]: time disparity of 1366850 minutes detected
Dec 9 10:55:28 wlceventd: wlceventd_proc_event(510): eth6: Auth 70:2C:1F:79:6F:8B, status: Successful (0)
Dec 9 10:55:28 wlceventd: wlceventd_proc_event(539): eth6: Assoc 70:2C:1F:79:6F:8B, status: Successful (0)
Dec 9 10:55:31 roamast: ROAMING Start...
Dec 9 10:55:32 acsd: eth7: NONACSD channel switching to channel spec: 0xd024 (36)
Dec 9 10:55:40 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
Dec 9 10:55:52 wlceventd: wlceventd_proc_event(510): wl0.1: Auth 58:B1:0F:8B:66:96, status: Successful (0)
Dec 9 10:55:52 wlceventd: wlceventd_proc_event(539): wl0.1: Assoc 58:B1:0F:8B:66:96, status: Successful (0)
Dec 9 10:55:54 kernel: bcm_i2c: bus 0: Failed to detect SFP: 100 retries exhausted
Dec 9 10:55:56 wlceventd: wlceventd_proc_event(474): wl0.1: Deauth_ind 58:B1:0F:8B:66:96, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Dec 9 10:55:57 wlceventd: wlceventd_proc_event(510): eth6: Auth 58:B1:0F:8B:66:96, status: Successful (0)
Dec 9 10:55:57 wlceventd: wlceventd_proc_event(539): eth6: Assoc 58:B1:0F:8B:66:96, status: Successful (0)
Dec 9 10:55:59 wlceventd: wlceventd_proc_event(491): eth6: Disassoc 58:B1:0F:8B:66:96, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Dec 9 10:56:00 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
Dec 9 10:56:01 wlceventd: wlceventd_proc_event(510): eth6: Auth 58:B1:0F:8B:66:96, status: Successful (0)
Dec 9 10:56:01 wlceventd: wlceventd_proc_event(520): eth6: ReAssoc 58:B1:0F:8B:66:96, status: Successful (0)
Dec 9 10:56:01 kernel: br0: received packet on eth6.0 with own address as source address
Dec 9 10:56:04 pppd[1400]: Timeout waiting for PADO packets
Dec 9 10:56:08 wlceventd: wlceventd_proc_event(510): eth6: Auth 80:C5:F2:BC:8C:21, status: Successful (0)
Dec 9 10:56:08 wlceventd: wlceventd_proc_event(539): eth6: Assoc 80:C5:F2:BC:8C:21, status: Successful (0)
Dec 9 10:56:20 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
Dec 9 10:56:34 hour monitor: ntp sync fail, will retry after 120 sec
Dec 9 10:56:40 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
Dec 9 10:57:00 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
Dec 9 10:57:04 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7035)]periodic_check AM 2:46
Dec 9 10:57:19 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7099)]could not retrieve firmware information: webs_state_update = 1, webs_state_error = 1, webs_state_dl_error = 0, webs_state_info.len = 0
Dec 9 10:57:19 pppd[1400]: Timeout waiting for PADO packets
Dec 9 10:57:20 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
Dec 9 10:57:40 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_netlink_process_snoop_cfg,884: interface 33 could not be found^[[0m
I have the same Let's Encrypt issue, everything else seem to be working well for me. By the way are you using RT-AC88U as per your signature or RT-AX88U as per title of this threadJust flashed it myself
let's encrypt stuck on authorizing,did factory default
same issue
RT-AX88UI have the same Let's Encrypt issue, everything else seem to be working well for me. By the way are you using RT-AC88U as per your signature or RT-AX88U as per title of this thread
how i can use the port 80 to access the 192.168.50.1? not use http://192.168.50.1:81,please help me, thank you!
I am using RT-AX88U (3.0.0.4.386_41249) as the router and 2 AiMesh nodes are ZenWifi AX XT8 a.k.a. RT-AX95Q (3.0.0.4.386_25790).
I set the guest network Sync to AiMesh Node to "All" but the guest network does not broadcast from the nodes. It only broadcasts from the router.
Does anybody else have the same problem? Has anybody successfully propagated the guest network to a node running 386 FW?
i can't find where to config my ax88u,how to modify the port 81 to 80 in the router when i access it from wifi?
Welcome To SNBForums
