ASUS RT-AX88U - New Firmware 3.0.0.4.384.9559 Released July 28, 2020
FTC
ASUS RT-AX88U Firmware version 3.0.0.4.384.9559
- Fix CallStranger vulnerability (CVE-2020-12695)
- Improved system stability.
Please post your experiences... specially if this version does improve the 2.4Ghz band wifi radio power.
Nice to see an update after 2.5 months, but 386_RC2 firmware is doing brilliantly here since 10 days. Once you install that and get used to new Aimesh 2.0 and support for 802.11k/v, there is no going back.
Would you dare to say your wireless clients are roaming faster... more seamless?
OE
After upgrade to this new firmware, my node - RT-AX92U will be deauthenticated and authenticate again hourly.
Part of syslog:
Jul 29 23:39:26 wlceventd: wlceventd_proc_event(464): eth7: Deauth_ind 04:D9:F5:27:41:E8, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Jul 29 23:39:45 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
Jul 29 23:41:33 wlceventd: wlceventd_proc_event(499): eth7: Auth 04:D9:F5:27:41:E8, status: Successful (0)
Jul 29 23:41:33 wlceventd: wlceventd_proc_event(527): eth7: Assoc 04:D9:F5:27:41:E8, status: Successful (0)
Jul 29 23:41:34 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 2 wfd_idx 1
Jul 29 23:41:34 kernel: Register interface [wds1.0.1] MAC: a8:5e:45:ae:84:94
Jul 30 00:22:48 wlceventd: wlceventd_proc_event(499): eth6: Auth 04:CF:8C:A2:52:AB, status: Successful (0)
Jul 30 00:22:48 wlceventd: wlceventd_proc_event(527): eth6: Assoc 04:CF:8C:A2:52:AB, status: Successful (0)
Jul 30 00:23:08 wlceventd: wlceventd_proc_event(464): eth6: Deauth_ind 04:CF:8C:A2:52:AB, status: 0, reason: Disassociated due to inactivity (4)
Jul 30 00:39:26 wlceventd: wlceventd_proc_event(464): eth7: Deauth_ind 04:D9:F5:27:41:E8, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Jul 30 00:39:27 wlceventd: wlceventd_proc_event(499): eth7: Auth 04:D9:F5:27:41:E8, status: Successful (0)
Jul 30 00:39:27 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
Jul 30 00:39:29 wlceventd: wlceventd_proc_event(464): eth7: Deauth_ind 04:D9:F5:27:41:E8, status: 0, reason: Unspecified reason (1)
Jul 30 00:39:29 wlceventd: wlceventd_proc_event(499): eth7: Auth 04:D9:F5:27:41:E8, status: Successful (0)
Jul 30 00:39:29 wlceventd: wlceventd_proc_event(527): eth7: Assoc 04:D9:F5:27:41:E8, status: Successful (0)
Jul 30 00:39:30 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 2 wfd_idx 1
Jul 30 00:39:30 kernel: Register interface [wds1.0.1] MAC: a8:5e:45:ae:84:94
Jul 30 00:39:33 wlceventd: wlceventd_proc_event(464): eth7: Deauth_ind 04:D9:F5:27:41:E8, status: 0, reason: Station requesting (re)association is not authenticated with responding station (9)
Jul 30 00:39:33 wlceventd: wlceventd_proc_event(481): eth7: Disassoc 04:D9:F5:27:41:E8, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jul 30 00:39:33 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
Jul 30 00:41:48 wlceventd: wlceventd_proc_event(499): eth7: Auth 04:D9:F5:27:41:E8, status: Successful (0)
Jul 30 00:41:48 wlceventd: wlceventd_proc_event(527): eth7: Assoc 04:D9:F5:27:41:E8, status: Successful (0)
Jul 30 00:41:48 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 2 wfd_idx 1
Jul 30 00:41:48 kernel: Register interface [wds1.0.1] MAC: a8:5e:45:ae:84:94
I installed this update and I regularly lost the internet connection; the connection is lost after some (short) undetermined time and also ALWAYS after a reboot there is no internet connection.
Only after unplugging and re-inserting the wan network-cable is internet restored.
I have now downgraded to the previous firmware and this fixed the problem immediately.
Noticed Version 3.0.0.4.384.9566 was up on the ASUS USA site today.
Link: https://www.asus.com/us/Networking/RT-AX88U/HelpDesk_Download/
Give them time, takes a day or two for new downloads to fully propagate through their server farms.
Sure enough, it's under the BIOS listing now.
Did anybody see any difference in the 2.4Ghz band wifi radio power? Any improvement in the signal strength or coverage?
