Evening.
Recently replaced my Nighthawk R7000 with the RT-AX88U due to the R7000 starting to give up with weekly reboots.
Set the AX88U up and am currently running the stock updated firmware and have all my devices connected with static IP's and the network is now running smooth with no need for reboots.
My issue is the speed at range. The Asus is in exactly the same position as the Nighthawk with Antennas in the same positions but my range has dropped significantly.
For instance if I stand 1 metre from both routers I get the full 350Mbit via WiFi.
If I move to the bedroom where I previously got 280Mbit with the Nighthawk I now get about 200Mbit with the Asus.
And in the Living Room I was getting 190MBit with the Nighthawk I now just about get 100Mbit.
I have separate SSID's and everything on my network and devices is exactly the same as it was with the Nighthawk so it is purely down to something to do with the Asus Router.
Forgot to mention I use Channel 11 for 2.4GHz and Channel 44 for 5GHz as this is exactly what was used before on the Nighthawk.
Just wondering if anyone has any suggestions on settings I could possibly change to improve range or is it just something I'll have to get used to?
Thanks in advance.
Keegs.
Thanks in advance.
Keegs.
