I have a RT-AX88U with the latest Merlin firmware (384.17) and have a harddrive connected to the USB, after a restart of the router, the harddrive is discovered and I can use it to read and store data, but after some hours the harddrive is disconnected and I can't reach it anymore. The router report that not harddrive i detected and even if I disconnect it and reconnect it, the router doesn't detect it, I have to circlepower the router to find it again...
Anyone have the same problem?
Is it a known problem?
I have own several router from Asus and on some the harddrive is working all the time perfectly, on other, it does the same thing, disconnect after some hours and never connect it again...
Thanks for any help.
