As the title of this post pretty much explains the question I am trying to figure out an answer for and any tips or suggestion's would be greatly appreciated..
I made a recent purchase of this router and it is a very nice bit of kit indeed..
BUT and this is a huge BUT...
..where can I customise which IPv4 address(es) to either specifically allow/disallow/reject?
I can see the Famous IPv6 IP/CIDR list <Inbound Firewall Rules (Max Limit : 128)>
But NO IPv4 Addresses are allowed to be entered.
If I head here :-
http(s)://<gatewayhostname.domain.lan>/Advanced_BasicFirewall_Content.asp
It offers these as inputs:
Service Name | Remote IP/CIDR | Local IP | Port Range | Proto| Add/ Del
The GUI form only accepts IPv6 addresses nothing for IPv4.
Am I stupid? and/or missing something completely obvious?
The only other location would be under the Network Services Filter Table (Max Limit : 32)
This is not the same as being able to flat-out Block/reject <IPv4 address range/24> linked to an ASN block list which I want to be able to block.
To hopefully help provide some extra clarity to what it is Im trying to achieve and to gather more tips/advise for trying to solve my problem I want to be able to actively go in to my router (during an active scanning attempt) and block a single IP address OR if called for a IP Range/block of addresses linked to a malicious network mapped back to a particular ASN.
Let's Say for example:
If I need to block all or a large chunk of DigitalOcean VPS's as this is where most of my issues are originating from; How would I be able to achieve this through the Asus Routers interface, There is Nothing clear up on Asus own knowledgebase? The only place I found something resembling close to what I want to achieve is from expressvpn
As shown in this URL: https://www.expressvpn.com/support/troubleshooting/asus-block-ip-address/
This method provides nowhere near enough granularity to block individual ips from the ip range of the remote machines without doing a total block of a /24 CIDR which equates to a lot of addresses.
Also, this method does not allow me to use a refreshed block list of IP addresses, which are up on git gist ready to be pulled into the router via wget xxx which contain the latest active Strecinoid hosts I have queried and derived from the Stretchoid domain PTR records..
Any suggestions Tips would be a massive help.
Alas, Not able to UG to Merlins firmware as not available on AX89X.. There must be another way to block these Aggressive IP/port Scanners based on their IP's and a method to pull a fresh list of IP's down from git gist and imported into the router ipset rules.. idk.. Im Stuck.
Cheers
If I head here :-
Cheers
