Honestly, the only tip I can give you is return this RT-AXE7800 to Amazon and get one of the Pro series instead - RT-AX86U Pro or better. This router is actually weaker hardware compared to your old router and similar to mid-range RT-AX82U V2 model hardware. The 3.0.0.4 firmware (Asuswrt 4.0) it is running will never be updated to 3.0.0.6 (Asuswrt 5.0) and perhaps this model will have shorter life compared to Pro series. The CPU used is ARMv7 and if you decide at some point to try VPN client/server you'll be disappointed by slow performance. The Pro series routers have much faster ARMv8 CPU and will move on to 3.0.0.6 firmware base perhaps by the end of this year.
Hi Thanks for the information I'll keep that in mind and see how I go I've absolutely plenty of time to send that back to Amazon and exchange it for the other router if I want to .Honestly, the only tip I can give you is return this RT-AXE7800 to Amazon and get one of the Pro series instead - RT-AX86U Pro or better. This router is actually weaker hardware compared to your old router and similar to mid-range RT-AX82U V2 model hardware. The 3.0.0.4 firmware (Asuswrt 4.0) it is running will never be updated to 3.0.0.6 (Asuswrt 5.0) and perhaps this model will have shorter life compared to Pro series. The CPU used is ARMv7 and if you decide at some point to try VPN client/server you'll be disappointed by slow performance. The Pro series routers have much faster ARMv8 CPU and will move on to 3.0.0.6 firmware base perhaps by the end of this year.
My next step is to set it up with brand new Wireguard VPN along with my surfshark account and if that works
I'm not going to no point
Fair enough... Again I'll leave things as they are with what I've decided to do .You'll get around 300Mbps on WireGuard and 100Mbps on OpenVPN. A Pro model router can get around 500Mbps on WireGuard and 250Mbps on OpenVPN. This is where the big difference is. Not to mention something like RT-AX86U Pro may be actually cheaper and takes less space. The 6GHz band you have on RT-AXE7800 is mostly for marketing purposes. It's a weaker 2-stream radio with less range. Best used perhaps as dedicated wireless link to something like VR set in the same room.
I'm not so fussed if the other router essentially has a slightly higher spec CPU and memory ...
Hi Yes thats correct !....Thanks for the answer I will check and have some interesting reading to do .Your money, your decisions.
Tips and Tricks - it runs Asuswrt 4.0, whatever is available on similar routers.
Specifics - you may have to wait a bit, this router is not popular model around.
Asuswrt 4.0 features advertisement here:
Welcome To SNBForums
