Hi all. Really interested in buying a BE88U for the number of 2.5G and 1G ports though I am needing to clarify two things.
1) On the BE88U, there are two 10G ports, one copper and one fiber. I am wanting the 10G copper port on the BE88U to connect to my 10G Google Fiber Box (GR6EXX0C) at 10G. This is a WAN port so this should work. I also want to utilise the 10G fiber port on the BE88U though this would connect downstream to a third-party switch that has 10G fiber also. Would this work given it may be a WAN port instead of LAN? I can tell with the documentation so far.
2) If the above works, does the BE88U support 802.1q tagging? Ideally I would like to do VLAN tagging to the 10G fiber port on the BE88U. My Third-party switch supports tagging.
