ASUS RT-N12 - UPnP
Gew
Hi guys!
I just bought a ASUS RT-N12. Works fine. However, I thought I'd enable UPnP for some applications that uses it. However, I couldn't find it anywhere in the web configuration interface. I started to think that perhaps the router doesn't support it (some people believe that UPnP is a buggy standard anyways, so maybe ASUS had decided not to go with it, or something). However, I tried some UPnP applications and they seemed to self-configure themselves just fine. Apparently, UPnP is enabled by default. Now, this leads me to my next question. How to turn it off, is it even possible? Is it perhaps called something other than "UPnP" in the configuration interface? Oh, I'm running stock firmware (v1.0.1.2).
Any help would be much appreciated.
Ty in advance~
Regards~
Problem solved.
Thanks a lot for your input here GregN.
Indeed, it was under Advanced / WLAN / Internet Connection.
Cheers~
