ASUS RT-N18U Bricked while flashing
alexpa940
This is my first post on this forum and please forgive me for my English. I flashed lastets original rom but router turned off during fw upgrade. PC doesn't detect router connected via LAN. I tried to use uart adapter but there are only strange symbols.
Help me please... :( :( :(
How can I recover my router??
Thank you very much.
Set a static ip on your computer. 192.168.1.9, 255.255.255.0, 192.168.1.1.
Start a continuous ping. Open a CMD window and type: ping 192.168.1.1 -t
Unplug the router. Hold the reset button in while plugging the power back in.
Keep holding the reset button in until the power led flashes. Your ping responses at this point should say ttl=100.
Open your browser at 192.168.1.1. You should see the option to upload the firmware.
Either you are using the wrong type of adapter or your putty settings are wrong.
Settings seem correct. Only connect ground, tx and rx.
Touch your rx and tx leads. Do your keystrokes show in putty?
