Asus rt-n66u minidlna audio freezing
kiesa1231
Asus rt-n66u minidlna mkv audio freezing
Hello all i have problem with minidlna.When i watch mkv files on tv audio some times freezing.How fix this problem?Video show good without freezing.Freezing only sound.I watch mkv with high video bitrate about 10mbps.I installed asus merlin build 3.0.0.4.374.36_beta1 but problem still is please help thanks.
Did you do a restore to defaults when you flashed the latest? Did you try the SDK5 version? Again, when moving between SDK5 and SDK6 versions you need to restore to defaults, power off the router (not reboot with the web gui) and manually enter any settings you require (don't restore old settings, it negates the restore to defaults step you should have done).
How good is your throughput to the TV? Not the indicated connection rate - the actual transfer rate. Have you tried different channels? Different power levels for TX (I suggest you try 100mW)? What channel width are you running (20MHz or 40MHz)? What band (2.4GHz or 5GHz)? How far is the router from the TV?
Guessing:
You may need to simply lower the bitrate or use a different format and not mkv if all the above are set up optimally.
minidlna merely streams the file as it is to your device, without any processing. It's possible that it's your TV that's chocking on the codec used in that file, or the container itself.
