Hi all, I have used an Asus RT-N66U router for several years now and it has worked flawlessly with my VOIP provider. Last week while checking up on the router and I noticed I was a few firmware updates behind so I decided to do an update.
Unfortunately after the firmware update my VOIP connection died. After an hour or so of trouble shooting and testing I discovered the SIP NAT Passthrough, which had to be DISABLED in the past to make a VOIP connection, now has to be ENABLED.
The Release Notes don't mention anything about the change and perhaps it's just my setup. Has anyone else experienced or noticed this change?
Thanks for the help!
