Turn on Wireshark and see what it says. For my RT-AX86U it's normal STP with a hello time of 2 seconds. That said, if you look in the syslog you can see that it reacts to topology changes pretty quickly.Do I understand correctly that the Asus router uses the classic Spanning Tree Protocol (STP) and not Rapid STP (RSTP) and Multiple STP (MSTP)?
That's not what that article is demonstrating.but the first link shows why it's time to retire any 10/100 switching you're still using, especially if you're closer to 1Gbps connection to WAN.
robocfg reports it as well.
UseASUSWRT-Merlin RT-AX68U 386.5_2
RT-AX68U# robocfg show
-sh: robocfg: not found
brctl show
and brctl showstp br0
# tcpdump -i eth1 llc
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth1, link-type EN10MB (Ethernet), capture size 262144 bytes
20:17:15.542196 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:17.542217 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:19.542169 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:21.542187 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:23.542171 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:25.542197 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:27.542195 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:29.542204 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:31.542214 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
20:17:33.542197 STP 802.1d, Config, Flags [none], bridge-id 8000.f0:2f:74:92:37:d8.8004, length 35
Welcome To SNBForums
