fruitcornbread
Version 3.0.0.4.388_33474
39.38 MB
2024/06/05
Bug Fixes and Enhancements:
- Enhanced AiMesh Stability
- Fixed an issue where the Aimesh node information was not being updated in the AiMesh topology.
- Added DS-Lite Support.
- Corrected a display issue in the OpenVPN server that prevented IPv6 settings from showing correctly.
- Fixed a persistent GUI issue on 'Let's Encrypt Authorization' that displayed 'Authorization' incorrectly.
- Resolved a bug that prevented offline devices from being deleted in the Router App.
- Fixed an issue where the system would reboot due to parental control rules with empty enable fields.
- Resolved an issue where the Traffic Analyzer feature was not functioning properly.
Security updates:
- Addressed CVE-2023-48795 by updating the dropbear SSH server.
- Applied patches for CVE-2023-5678 & CVE-2024-0727 from the Ubuntu Repository.
- Improved security in OpenVPN custom configuration.
Please unzip the firmware file, and then verify the checksum.
SHA256: 2df6883ad9d17c9a40176c7f85657071eab34052992468c58c3b86200f4572d3
Download: https://dlcdnets.asus.com/pub/ASUS/..._TUF_AX4200_300438833474.zip?model=TUF-AX4200
Based on the release notes, this version should be very similar to the latest TUF-AX6000's 3.0.0.4.388_33405 which is supposed to fix Traffic Analyzer (RT-AX59U's 3.0.0.4.388_33391 doesn't seem to receive yet).
39.38 MB
2024/06/05
Security updates:
