Asus TUF AX5400 wi-fi problem
Lezly
Hello!
I have a TUF AX5400 router. The wifi gave up on it last week. I've been trying to fix it ever since, I read most of the tips here on this forum. I feel like I've tried everything, but I'm sure someone can help.
So the specific problem is that there is wan access, but no wifi signal. The 5GHz light doesn't even light up. But there is no 2.4 GHz signal either. Tried a lot of firmwares, now it has the latest Merlin firmware. I tried the hard reset, then flashed the firmware with the Firmware Restoration tool. Nothing was used, the "usual" error came: "The Country Code does not exist! Please enter Country Code."
I read that several people managed to fix this error, please help me to solve it.
Thanks!
You may need a new router.
Thanks for the answer!
This thread escaped my notice.
Unfortunately, this is bad news! I hope my new router won't get infected.
Check if you have any warranty left. If yes - call Asus Support, tell them it stopped working, get RMA.
Unfortunately, it is no longer under warranty.
However, I have a silly question: Couldn't the connected external hard drive have been corrupted by this malware?
Thank you!
I don't know. The router is not the best place to connect HDD to to begin with. It may get corrupted with no malware.
