Good afternoon, I have a problem with Wireguard.
I have a Proton VPN and I downloaded the configuration for the router and when I switch it on, I have a speed of 200 Mbps through the VPN, it's a great speed. And when I download the configuration for the PC and switch it on at the same time, my speed on the PC drops to 300mbit/s instead of 500mbit/s, but here's the problem, when I switch off the VPN configuration on the router, my speed through wireguard starts at the full "500mbit" on the PC. I've noticed that when I switch on the configuration on the PC while the VPN on the PC is on, the router starts booting up, ie booting itself, which shouldn't be the case, the data is going through to the PC and it should be handling it, not the router.
I have tried other VPNs and it is the same if you have two configurations, one on the router and one on the PC, even though the configurations are different.
