Asus USB-C2500 2.5GB Adapter
FunctionJuan
I think it was mentioned from a previous question that most Asus routers do support this Asus Adapter (USB-C2500) 2.5 GBe.
I have a GT-AX1100 and wanted to implement this as "Network USB" either LAN or WAN to have that extra port.
Does Merlin support this Asus adapter ?
Thanks for anyone's help!
Asus Merlin is based on Asus firmware. There are a number of prior posts that come up in a forum search indicating the USB-C2500 works on Asus routers.
https://www.snbforums.com/search/1232298/?q=C2500&o=relevance
For example some discussion in the following link about the USB-C2500 working on Asus router using Asus-Merlin. Including how Dual WAN may not work properly with USB network adapters.
