Asus wireguard VPN server
mike001
I have a xt 12 and been working on the wireguard setup for 2 days and can't access work lan. Openvpn server works perfectly. I have read all the posts regarding this and can't get it to work, watched videos. I used default values. Work is 192.168.1.1 and VPN server is default 10.6.0.1/32
Fixed it. Works perfect. So if your having trouble with VPN server wireguard and VPN fusion at the same time trying to remotely connect to a PC. Disable VPN fusion first then configure wire guard server then turn VPN fusion back on.
