Hi All,
I'm new here but from googling seemed to be my best hope of an answer.
I took a gamble on a "faulty" XT8 (AX6600) on a well known auction site, with the description that it powered up but wouldn't connect to the app for setup. I assume the original owner made a warranty claim and this was the left over device. I thought it sounded like something that a firmware update might solve, but also went in fully in the knowledge that I might be wasting my money. I'm by no means an expert but thought it was worth a try.
I'm able to boot into the router and enter the initial setup.
If I set up as a router / access point, there is seemingly no WiFi broadcast but LAN/Routing work fine.
If I set up as Repeater / Bridge, it is able to detect the existing WiFi networks i nthe area during setup, but when it goes to reboot after setup, it cannot connect to them.
The only other things I have by way of a clue is this repeated log entry
kernel: MDIO Error: MDIO got failure status on phy 31
I confess to not being expert enough to understand that directly and despite some create googling the only similar reference I can find concerning an asus product is on a chinese forum and if google translate is to be believed resolved itself.
I've tried factory reset (several times), I've tried a few different versions of firmware, flashing through the WebUI and also the firmware recovery tool (in rescue mode)
I'm more curious than expecting that I am actually able to fix it as to my mind the symptoms seem quite strange and am using this as a learning exercise to understand more about what is going on in my router!
Many thanks for reading and in advance for any insights you have.
