Hi all,
quick newbie question with my new Asus xt8 mesh system at home.
1. I have an FTTH 1gb Connection from my isp and a Fritzbox 5490 that came with it. As unfortunately I can’t run the Fritzbox in bridge mode I have currently configured the first xt8 (connected via lan into the wan port) as access point and then added the second node to it through the mobile app to avoid double nat. Now I just wanted to check if this is best practice or if you would go with double nat to take advantage of the additional Features of the xt8 instead or if you would use the AP mode as well?
2.Both nodes seem to be connected with each other via dedicated 5ghz-2 Backhauland over wifi I currently get around 500-600mbps on both nodes. When I first set up the initial router via lan to my Fritzbox it automatically was set up as router with double nat (second node was not yet connected). I only did one quick speed check back then before switching to ap mode. However back then I received roughly 800mbps. My question is now - do you think this was due to the fact that my iPhone 11 Pro Max was able to connect to the faster 5ghz-2 band or because the set up as router improves the speed of the network?
3. Do you prefer using the 5ghz-2 as dedicated Backhaul or would you allow your endpoints to also use this band?
4. As my apartment does not allow for a wired backhaul i was thinking about getting a power line backhaul between my 2 nodes. Would you recommend that over a dedicated/non-dedicated backhaul between the nodes?
5. Firmware: I have read a lot on this Forum about People using beta firmwares on their xt8. However I did not understand why. Is there any specific advantage over the official non beta firmware at the moment?
thanks in advance
Seb
thanks in advance
Seb
