Hello,
I have read lot's about problems with the XT8 but didn't find anything that solves my issue. Apologies if reposting.
My XT8 router's WAN port does not detect the 1Gbps modem connection and only reports 100Mbps.
- I have placed a switch between the router and the modem to verify link speed. The switch detects 1Gbps connection from the modem but only 100Mbps to the XT8. (If I switch the cables the result is the same).
- The other (LAN) ports on the router work correctly at 1Gbps. Both according to the router UI and the switch.
- I have factory reset the XT8 router several times to no avail.
- The router runs at the latest firmware version.
