Asus XT8 weird logs entries on 42095
CarsonL
This may seem weird, but I'm getting a bunch of log entries on my XT8s and random restarts from time to time.
My Current setup : Wireless Backhaul with DFS disabled, Backhaul under WPA-3.
Network : Average of 3-4 GB usage per hour consistently.
Log entries :
May 5 13:05:13 crashlog: <6>protocol 8100 is buggy, dev wds2.0.1
May 5 13:05:13 crashlog: <4>net_ratelimit: 2002 callbacks suppressed
May 5 13:06:00 miniupnpd[1760]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
May 5 13:06:00 wan: finish adding multi routes
May 5 13:06:00 miniupnpd[1760]: shutting down MiniUPnPd
May 5 13:06:00 miniupnpd: it is advised to use network interface name instead of 192.168.50.1/255.255.255.0
May 5 13:06:00 miniupnpd[2739]: HTTP listening on port 50102
May 5 13:06:00 miniupnpd[2739]: Listening for NAT-PMP/PCP traffic on port 5351
May 5 13:06:00 wlceventd: wlceventd_proc_event(556): eth5: Assoc D4:7A:E2:E0:7D:B4, status: Successful (0), rssi:0
May 5 13:06:04 WAN Connection: WAN was restored.
May 5 13:06:06 ntp: start NTP update Mar 17 20:00:58 rc_service: ntp 2735:notify_rc restart_diskmon
Mar 17 20:00:58 disk_monitor: Finish
Mar 17 20:00:58 disk monitor: be idle
Mar 17 20:00:59 wlceventd: wlceventd_proc_event(556): eth5: Assoc BA:C0:91:62:97:AA, status: Successful (0), rssi:0
Mar 17 20:02:16 kernel: net_ratelimit: 1766 callbacks suppressed Mar 17 20:02:22 kernel: net_ratelimit: 1010 callbacks suppressed
Mar 17 20:02:28 kernel: net_ratelimit: 2116 callbacks suppressed Mar 17 20:02:33 kernel: net_ratelimit: 1403 callbacks suppressed
Mar 17 20:02:36 wlceventd: wlceventd_proc_event(491): eth4: Deauth_ind 00:6B:8E:41:37:1E, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Mar 17 20:02:36 wlceventd: wlceventd_proc_event(556): eth5: Assoc 00:6B:8E:41:37:1E, status: Successful (0), rssi:0
Mar 17 20:02:37 wlceventd: wlceventd_proc_event(491): eth5: Deauth_ind 00:6B:8E:41:37:1E, status: 0, reason: Station requesting (re)association is not authenticated with responding station (9), rssi:0
Mar 17 20:02:37 wlceventd: wlceventd_proc_event(508): eth5: Disassoc 00:6B:8E:41:37:1E, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0 Mar 17 20:02:38 kernel: net_ratelimit: 1149 callbacks suppressed
Mar 17 20:02:39 wlceventd: wlceventd_proc_event(556): eth5: Assoc 00:6B:8E:41:37:1E, status: Successful (0), rssi:0 Mar 17 20:02:40 kernel: 00:6B:8E:41:37:1E not mesh client, can't update it's ip
Mar 17 20:02:42 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7058)]periodic_check AM 2:40
Mar 17 20:02:44 kernel: net_ratelimit: 1744 callbacks suppressed
Mar 17 20:02:44 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7088)]retrieve firmware information
Mar 17 20:02:44 WATCHDOG: [FAUPGRADE][auto_firmware_check:(7091)]user in use
Mar 17 20:02:49 kernel: net_ratelimit: 2175 callbacks suppressed
Mar 17 20:02:54 kernel: net_ratelimit: 2137 callbacks suppressed
Mar 17 20:02:55 ahs: [read_json]Update ahs JSON file.
Log entries :
May 5 13:05:13 crashlog: <6>protocol 8100 is buggy, dev wds2.0.1 <<<<< This keeps pops up, as much as 50 entries in 1 time. Then it also mentions Stopping CPU 1, 2, 3, 4. No idea what these means. The last few entries of the log files also mentions "Mar 17 20:05:04 kernel: net_ratelimit: 2188 callbacks suppressed" these also clogges up the log files as well.
May 5 is the date it shows after it restarts, before it syncs with the time server.
No idea. You'd be more likely to get a useful response from Asus.
