Guys, I have 3 XT9 on my setup, with a lot of GUI setups.
I have found out that some devices that I have inside my network(2 in total, which are the same) have trouble to be consistent in connecting on my WIFI.
The problem is that sometimes they connect just fine and sometimes are not. They are getting their IP address through DHCP.
I have found the link about this devices from your support site, but I do not want to disable WIFI6(802.11ax), since this is the reason that I have bought the mesh system in the first place.
I have assigned to these problematic devices static IP addresses and guess what, the problem disappeared
The second issue is that under network map, If I select interfaces I cannot see the clients per category. In order to resolve the issue I need to restart my router. Afterwards, the problem is resolved until I do multiple changes to the configuration on my Asus system. Then, the problem reappears.
The last issue, is that a DHCP WIFI device was changed from DHCP to static IP address. It's IP address is successfully chanced but under the display of the clients I still see the old IP address.
Any ideas? I guess that all this might be present to other Asus Router.
