Hi all,
I have recently come across an issue with my ASUS ZenWiFi AX (XT8) (2x nodes) where devices intermittently disconnect and do not seem to be able to reconnect.
I observe that some security cameras and baby monitor disconnect from the router, and do not seem to be able to connect back until I reboot the device or router. This doesn't happen for all the camera, but does appear to consistently affect the same ones.
In addition to this, I have observed that by Pixel 7 phone sometimes was constantly connecting and disconnecting from the network (i.e switching from wifi to 5g and back constantly). This behavior appeared around the same time as the other issue above.
This problem seems to have only started when I switched internet providers. Previously I was bridging the router to Virgin Media modem via its ethernet port. But now I am with Vodafone, and I am using one of the Asus nodes as a WAN PPPoE connection to the internet provider directly, using the ethernet port from my ONT, instead of using the Vodafone modem. Could it be related and causing my issues?
What I tried:
The router was using "Smart Connect", however I since did a hard factory reset on both nodes, and then disabled "Smart Connect" and separated out the 2.5 and 5ghz networks. This seems to have fixed the constant disconnecting/reconnecting on my Pixel 7, and it connects to either the 2.4 or 5ghz, whichever has best signal. However, the cameras which only work on the 2.4ghz network have the issue remaining.
In my router logs, I see excessive entries for some MACs around:
(Note: I masked the MACs)
A count of the number of times `Disassociated because sending station is leaving` appears per MAC in the logs:
Is this a known problem? Is there anything else I can try? Could it be related to use the router for a WAN PPPoE connection?
What I tried:
Jan 6 16:21:09 wlceventd: wlceventd_proc_event(645): eth4: Deauth_ind 11:22:33:72:65:B9, status: 0, reason: Disassociated due to inactivity (4), rssi:-63
Jan 6 16:21:09 wlceventd: wlceventd_proc_event(645): eth4: Deauth_ind 11:22:33:72:65:B9, status: 0, reason: Previous authentication no longer valid (2), rssi:-63
Jan 6 16:21:10 wlceventd: wlceventd_proc_event(662): eth4: Disassoc 11:22:33:72:65:B9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 6 16:21:20 wlceventd: wlceventd_proc_event(685): eth4: Auth 11:22:33:72:65:B9, status: Successful (0), rssi:0
Jan 6 16:21:20 wlceventd: wlceventd_proc_event(722): eth4: Assoc 11:22:33:72:65:B9, status: Successful (0), rssi:-57
Jan 6 16:21:49 wlceventd: wlceventd_proc_event(645): eth4: Deauth_ind 11:22:33:72:65:B9, status: 0, reason: Disassociated due to inactivity (4), rssi:-63
Jan 6 16:21:49 wlceventd: wlceventd_proc_event(645): eth4: Deauth_ind 11:22:33:72:65:B9, status: 0, reason: Previous authentication no longer valid (2), rssi:-63
Jan 6 16:21:50 wlceventd: wlceventd_proc_event(662): eth4: Disassoc 11:22:33:72:65:B9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 6 16:22:25 wlceventd: wlceventd_proc_event(685): eth4: Auth 11:22:33:72:65:B9, status: Successful (0), rssi:0
Jan 6 16:22:25 wlceventd: wlceventd_proc_event(722): eth4: Assoc 11:22:33:72:65:B9, status: Successful (0), rssi:-58
Jan 6 16:22:47 wlceventd: wlceventd_proc_event(645): eth4: Deauth_ind 11:22:33:72:65:B9, status: 0, reason: Disassociated due to inactivity (4), rssi:-63
Jan 6 16:22:47 wlceventd: wlceventd_proc_event(645): eth4: Deauth_ind 11:22:33:72:65:B9, status: 0, reason: Previous authentication no longer valid (2), rssi:-63
Jan 6 16:22:48 wlceventd: wlceventd_proc_event(662): eth4: Disassoc 11:22:33:72:65:B9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 6 16:23:44 wlceventd: wlceventd_proc_event(685): eth4: Auth 11:22:33:72:65:B9, status: Successful (0), rssi:0
Jan 6 16:23:44 wlceventd: wlceventd_proc_event(722): eth4: Assoc 11:22:33:72:65:B9, status: Successful (0), rssi:-58
Jan 6 16:24:10 wlceventd: wlceventd_proc_event(645): eth4: Deauth_ind 11:22:33:72:65:B9, status: 0, reason: Disassociated due to inactivity (4), rssi:-63
Jan 6 16:24:10 wlceventd: wlceventd_proc_event(645): eth4: Deauth_ind 11:22:33:72:65:B9, status: 0, reason: Previous authentication no longer valid (2), rssi:-63
Jan 6 16:24:11 wlceventd: wlceventd_proc_event(662): eth4: Disassoc 11:22:33:72:65:B9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 6 16:24:49 wlceventd: wlceventd_proc_event(685): eth4: Auth 11:22:33:72:65:B9, status: Successful (0), rssi:0
Jan 6 16:24:49 wlceventd: wlceventd_proc_event(722): eth4: Assoc 11:22:33:72:65:B9, status: Successful (0), rssi:-58
➜ ~ grep 'Disassociated because sending station is leaving' router.txt | awk '{ print $8} ' | sort | uniq -c
2 11:22:33:4B:4A:0F,
3 11:22:33:72:45:31,
2 11:22:33:CF:6E:8E,
2 11:22:33:CF:73:D5,
2 11:22:33:CF:7D:49,
1 11:22:33:D3:A5:7E,
3 11:22:33:40:75:5D,
2 11:22:33:0B:A0:B6,
1 11:22:33:34:AA:F5,
4 11:22:33:3D:81:70,
225 11:22:33:72:65:B9,
2 11:22:33:AD:10:4D,
2 11:22:33:AF:6A:C5,
576 11:22:33:FE:25:07,
2 11:22:33:1C:31:89,
6 11:22:33:0A:76:87,
8 11:22:33:20:35:EE,
4 11:22:33:99:28:65,
6 11:22:33:62:5B:3B,
5 11:22:33:8E:61:3F,
5 11:22:33:FC:81:47,
5 11:22:33:0A:D3:1A,
