Beta ASUS ZenWiFi Pro ET12 Firmware version 9.0.0.6.102.4856
saizzz
Link
Be noted: This is an early stage beta, there might be bugs. This version can be downgraded via web GUI only.
1. Recap new features of 3.0.0.6.102: Guest network Pro(SDN), VLAN, Auto USB WAN backup, iPhone tethering, Multi-services WAN.
2. Re-defined VLAN, supports Trunk, Access mode with VLAN-only-network.
3. Synchronize Guest network pro (SDN) with VLAN, create/delete new VLAN-only-network will create/delete a new profile in Guest network as well.
4. Port isolation and AP isolation to restrict device access to each other.
5. Re-defined multi-service WAN, disable it by default.
6. Add surfshark VPN in VPN fusion.
Please unzip the firmware file first then check the MD5 code.
MD5: fea839edfbcbe1f72e145ab8e02d2ee4
I hope this will fix the UI issue?
With the last beta, the UI becomes inaccessiable (very slow response) after the system is up for a few days and require hard reset.
I haven't tried it yet. Given the last firmware caused problems with wireless backhaul, I might wait to hear how others are doing.
Just to let you know guys that I installed this new Beta in my mesh system, so far everything is running with no issues. :)
I have a bit more complicated setup with 2 10G netgear unmanaged switch in between the ET12 router and 3 other ET12 mesh nodes. I find that on 22127, AiMesh can bonky across 2 switches (nodes are getting dropped with RED LED) while the wired clients (to the 2nd switch and the ET12s in Aimesh nodes mode) still connect fine. So a bit hestitant to try. Only stable firmware for me is the 21739..... If the AiMesh is stable in more complicated setups, I might give this a try.
I gave the new beta a try.. So far is ok.
No issue on UI not responding.
No issue on committing Wifi-Professional setting.
No on Guest network provided that you set the correct VLAN in the managed switch in between.
However it is just 1-2 days.. worth to take a longer look...
Took one for the team and upgraded. I was setup for dual WAN failover with fallback disabled. For some reason it would not use the primary WAN and always restarted with the backup active. I enabled failover and all seems to be working so far.
Setup: Router mode, three node mesh, wired backhaul, WAN failover.
I tried it, it seemed to improve things for my 6e speed, however I could not get this firmware to work with my Ring devices at all - just couldnt connect with them I guess. Reverted back and everything is hunky dory. Same network settings.
It happened to me with some devices and it was due to having wpa 3 on the 5gz. I put it to wpa2 personal only and that solved the problems. Hope it works for u
Yeah. I tried that unfortunately it worked for all devices except for the ring devices. I think it was something very specific to them.
