Release ASUS ZenWiFi XD4 Firmware version 3.0.0.4.388_25041 (2024/09/05)
fruitcornbread
Version 3.0.0.4.388_25041
55.17 MB
2024/09/05
Security Fixes
- Resolved command injection vulnerability.
- Resolved DoS vulnerabilities in HTTPD and firewall configuration pages.
- Addressed ARP poisoning vulnerability.
- Addressed information disclosure vulnerability.
- Corrected code execution issue in custom OVPN.
- Corrected an OpenVPN vulnerability categorized as CWE-134.
- Corrected null pointer dereference vulnerabilities.
- Patched OpenSSL vulnerabilities.
- Fix CVE-2022-46871 and CVE-2023-35720.
- Fix CVE-2023-28702 and CVE-2023-28703.
- Fix XSS and self-reflected HTML injection vulnerabilities.
- Enabled and supported ECDSA certificates for Let's Encrypt.
- Enhanced system stability.
- Enhanced FFmpeg vulnerabilities.
- Enhanced protection for OTA firmware updates and credentials.
- Improved several curl vulnerabilities.
- Improved the cfg server vulnerability.
- Improved WireGuard performance.
- Strengthened defenses against SSH brute force attacks.
Please unzip the firmware file, and then verify the checksum.
SHA256: a604d27590eb9012a643593ce3b4f100e9e828af8c010a41fc05b24cea9b59c3
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi Mini AX XD4/FW_ZENWIFI_XD4_300438825041.zip?model=ZenWiFi Mini AX XD4
It is interesting to see that the XD4 has finally got an update to 388. I have an XD4 as a mesh node (with an AX86U as the main AiMesh router) and it has worked well for 2 years.
I wonder how important it is for me to update the XD4 with this new firmware under my setup - I can see there are lots of vulnerabilities fixed but as I'm not using it as my primary router does that change anything?
Just don't want to apply this update and see problems when everything is good right now.
I’m hoping this heralds an update for the XD6 👌
