I purchased the Asus XT12 Pro and had it for about 3 months before I started having issues. I have the device setup in access point mode since I already have a network firewall that acts as my dhcp server.
My "primary" XT12 works without issues.
My 2nd node XT12 however constantly goes offline, the top of it turns red and all wireless devices drop off the node.
I have both the XT12's plugged in via ethernet using the 2.5 WAN.
I have the node set to use the 2.5 backhaul ethernet.
When its online it works fine but about ever 20-30 minutes it goes offline.
I have worked with ASUS support to no avail. They even sent me a new set of devices and the same issue is happening. The "primary" device is working fine but the node is going offline and dropping all connections.
I'm at a loss as to why this is happening. I almost get the impression its related to using ethernet on the 2nd node but that doesn't make sense since I would expect plugging in the 2nd node would be prefered to then provide better connection to the clients it servers.
Forgot to mention, there have been no firmware updates on the devices. They are on the current firmware for the past 4 months: 3.0.0.4.388_22127-gad91301
Any and all help would be appreciated to try and identify and resolve this.
