davekstl
I have a 6,000 sq ft house with 1 acre of property and I have been reading until I am at the saturation point. Reviews on 802.11ax products are over the place.
I have a Linksys WRT1900AC early version used in my previous 1,500 sq ft house and as expected it cannot reach the far end of my new world. I have range extenders in place and then I read they suck up bandwidth. My ISP delivers 200mbps, which can be raised to 400mbps for another 20 a month. I also have power adapters in place, but as the signal winds it's way through the electrical panel, they work but not ideal.
I have cameras on the far side of the house away from the router sending video to the Ring server. The rear of all of the properties here are the prime entry point to do evil.
Given the age of my router, I thought it was time to strike and was looking at the Asus Zenwifi xt8 as well as other products. The Asus marketing information suggests it is the right choice, but after reading information on your site, I am not so sure.
I do not have cable pulled, but I am one that if there is value and I get a strong bump for the expense, I am all in.
So is the Asus Zenwifi a bad choice? Is the mesh system a bad choice?
I can muddle my way through making a system work, my failures are in the design of a system.
So can you offer suggestions and opinions?
Dave
Dave
