Hi all,
I am having a very strange problem with my newly upgraded Asus RT-N66U, running on Merlin's firmware and was wondering if anyone could help.
Previous to my upgrade to 3.0.0.4.374.33_0, I was running 3.0.0.4.374.32_0, and had Entware and Privoxy set up with no problems. However, since the update, both refuse to stay installed after a reboot. They install successfully to /tmp/mnt/sda1, but as soon as I reboot, although the files remain present, running 'opkg list' presents a 'Command Not Found' error.
Consequently, this results in the devices that have been set up to use Privoxy via an IP address in the firewall-start page to not be able to access the internet as neither Privoxy nor Entware are running or enabled. I have tried a number of things, including formatting the USB Device, trying another USB devices, trying alternate file systems and retrying the commands to no avail. The only thing I have not yet attempted is a factory reset, which will be my next port of call.
Would anyone be able to shed some light on this?
Cheers.
Cheers.
