Dear Sir,
Can you add the no-IP.com at DDNS?
I using the DDNS cannot be use.
It haven't the this option to selection
No-IP has been supported for over two years now...
https://github.com/RMerl/asuswrt-merlin/blob/master/README-merlin.txt#L1954
Username = groupname:username [email address or username will work]
Password = the group password you just configured
Note: Some clients don’t like a colon) character as a separator, you can use the url encoded colon character %3A %23 or # if you run into this issue.
Sorry for that
Is Changeip.com
I get the mistake,
Can you add the CHANGEIP.com?
I need it,
Nothing like replying to content from 2014 in 2017. But I just wanted to say: "You sir, are a wizard". Thanks for integrating NoIP. That is going to make setting up my home security a breeze!No-IP has been supported for over two years now...
Welcome To SNBForums
