Asuswrt-Merlin SSH with RSA key
GoldWing
Hello,
After my initial experience in this forum I've learned that I need to learn a LOT. :)
So I've upgraded my router to an Asus GT-AX6000, and flashed the Asus-Merlin firmware version 388.1 per https://www.asuswrt-merlin.net/.
What I've done is loaded AMTM with Skynet per
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
which opened my eyes to what potential exploits that occur out on the Internet with your router.
After this initial experience I decided that SSH into the router via RSA keys would me most desirable for me going forward. WOW! What an experience trying to determine HOW to do that! I spent a LOT of time looking for the solution.
After reading a LOT I've found IMHO the most condensed solution per https://superuser.com/questions/130...ssh-login-on-router-with-asus-merlin-firmware which which was successful for me. So I thought that I'd post the URL, and hopefully save time to others.
I thought that a few additional links would be helpful for others attempting to upgrade their home LAN. From my reading I've learned that the Asuswrt-Merlin is written using Busybox which IIRC is a subset of Linux. If I'm wrong, please feel free to correct me! FWIW and FYI the additional links that I found helpful are below.
Regards,
GoldWing
After the initial euphoria after all of the research, subsequent success, and some after thought, I have to correct myself. :confused:
My problems with my earlier attempts and failures was the the public key pasted into the Asus's WUI was my public key did NOT have the carriage returns removed which are created when saving the public key using PuTTYgen's "Save Public Key" button which was what I used earlier in Asus's WUI. My bad! o_O
You really just have to just copy the public key in PuTTYGen interface text box with header "Public key for pasting ..." (dah) which is really all on 1 line and paste it to a text editor to paste latter into Asus's WUI. I removed the "/etc/dropbear/authorized_keys" file, and latter logged in with SSH successfully with my private key loaded into Putty. All you need is a key generator such as PuTTYgen for both the private and public key, plus a SSH client such as PuTTY to login into Asuswrt-Merlin after pasting your public key under Administration > System > Service. > Authorized Keys. BTW you may want to use a different port than the of 22. :)
What can I say other than the learning curve on public and private keys, PuTTY, PuTTYgen, Asuswrt-Merlin, SSH'ing. :eek:
See images below.
Regards,
GoldWing
